Abstract : We are interested in the inverse problem of recovering a Robin coefficient defined on some non accessible part of the boundary from available data on another part of the boundary in the nonstationary Stokes system. We prove a Lipschitz stability estimate under the a priori assumption that the Robin coefficient lives in some compact and convex subset of a finite dimensional vectorial subspace of the set of continuous functions. To do so, we use a theorem proved by L. Bourgeois which establishes Lipschitz stability estimates for a class of inverse problems in an abstract framework.
