A Note on k-support Norm Regularized Risk Minimization
The k-support norm has been recently introduced to perform correlated sparsity regularization. Although Argyriou et al. only reported experiments using squared loss, here we apply it to several other commonly used settings resulting in novel machine learning algorithms with interesting and familiar limit cases. Source code for the algorithms described here is available.
