Abstract : We consider unsteady single-phase flows modeled by the Richards' equation. We compare Discrete Duality Finite Volume and Discontinuous Galerkin schemes applied to discretize the diffusive term. Backward Differentiation Formula of second order is used for the time stepping method. Accuracy and robustness of these two types of schemes are tested and compared on various test cases, especially in anisotropic heterogeneous media.
Type de document :
Communication dans un congrès
SIAM Conference on Mathematical & Computational Issues in the Geosciences, Jun 2013, Padova, Italy
https://hal.inria.fr/hal-00817872
Contributeur : Vincent Baron
Soumis le : jeudi 25 avril 2013 - 15:02:41
Dernière modification le : jeudi 5 avril 2018 - 10:36:09
Vincent Baron, Yves Coudière, Pierre Sochala. Comparison of DDFV and DG Methods for Flow in Anisotropic Heterogeneous Porous Media. SIAM Conference on Mathematical & Computational Issues in the Geosciences, Jun 2013, Padova, Italy. 〈hal-00817872〉
