Analyzing Flowgraphs with ATL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a solution to the Flowgraphs case study for the Transformation Tool Contest 2013 (TTC 2013). Starting from Java source code, we execute a chain of model transformations to derive a simplifi ed model of the program, its control flow graph and its data flow graph. Finally we develop a model transformation that validates the program flow by comparing it with a set of flow specifi cations written in a domain speci c language. The proposed solution has been implemented using ATL.
TTC2013ATL.pdf (361.58 Ko) Télécharger le fichier
hal-00819075 , version 1 (30-04-2013)
  • HAL Id : hal-00819075 , version 1
Valerio Cosentino, Massimo Tisi, Fabian Büttner. Analyzing Flowgraphs with ATL. Transformation Tool Contest, Jun 2013, Budapest, Hungary. ⟨hal-00819075⟩
248 Consultations
244 Téléchargements
