HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Opacité des artefacts d'un système workflow
Abstract : A property (of an object) is opaque to an observer when he or she cannot deduce the property from its set of observations. If each observer is attached to a given set of properties (the so-called secrets), then the system is said to be opaque if each secret is opaque to the corresponding observer. Opacity has been studied in the context of discrete event dynamic systems where technique of control theory were designed to enforce opacity. To the best of our knowledge, this paper is the first attempt to formalize opacity of artifacts in data-centric workflow systems. We motivate this problem and give some assumptions that guarantee the decidability of opacity. Some techniques for enforcing opacity are indicated.
Document type :
Journal articles
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-00823005
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Friday, April 8, 2016 - 4:09:38 PM
Last modification on : Thursday, January 20, 2022 - 5:32:50 PM
Long-term archiving on: : Monday, November 14, 2016 - 11:51:23 PM
File
Vol.17.pp.177-196.pdf
Publisher files allowed on an open archive
Identifiers
Citation
Eric Badouel, Mohamadou Lamine Diouf. Opacité des artefacts d'un système workflow. Revue Africaine de la Recherche en Informatique et Mathématiques Appliquées, INRIA, 2014, Volume 17 - 2014 - Special issue CARI'12, pp.117-196. ⟨10.46298/arima.1973⟩. ⟨hal-00823005v2⟩
Share
Metrics
Record views
533
Files downloads
538
