A Survey of Software-Defined Networking: Past, Present, and Future of Programmable Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2013
The idea of programmable networks has recently re-gained considerable momentum due to the emergence of the Software-Defined Networking (SDN) paradigm. SDN, often referred to as a "radical new idea in networking", promises to dramatically simplify network management and enable innovation through network programmability. This paper surveys the state-of-the-art in programmable networks with an emphasis on SDN.We provide a historic perspective of programmable networks from early ideas to recent developments. Then we present the SDN architecture and the OpenFlow standard in particular, discuss current alternatives for implementation and testing SDN-based protocols and services, examine current and future SDN applications, and explore promising research directions based on the SDN paradigm.
SDN_survey.pdf (380.05 Ko) Télécharger le fichier
hal-00825087 , version 1 (24-05-2013)
hal-00825087 , version 2 (17-06-2013)
hal-00825087 , version 3 (29-10-2013)
hal-00825087 , version 4 (14-01-2014)
hal-00825087 , version 5 (19-01-2014)
  • HAL Id : hal-00825087 , version 1
Marc Mendonça, Bruno Nunes Astuto, Xuan Nam Nguyen, Katia Obraczka, Thierry Turletti. A Survey of Software-Defined Networking: Past, Present, and Future of Programmable Networks. 2013. ⟨hal-00825087v1⟩
3922 Consultations
37996 Téléchargements
