Second Order PDEs with Dirichlet White Noise Boundary Condition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Zdzislaw Brzezniak
  • Fonction : Auteur
  • PersonId : 941638
Francesco Russo
In this paper we study the Poisson and heat equations on bounded and unbounded domains with smooth boundary with random Dirichlet boundary conditions. The main novelty of this work is a convenient framework for the analysis of such equations excited by the white in time and/or space noise on the boundary. Our approach allows us to show the existence and uniqueness of weak solutions in the space of distributions. Then we prove that the solutions can be identified as smooth functions inside the domain, and finally the rate of their blow up at the boundary is estimated. A large class of noises including Wiener and fractional Wiener space time white noise, homogeneous noise and Lévy noise is considered.
bgpr_22-05-13_submitted.pdf (243.84 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00825120 , version 1 (23-05-2013)
Zdzislaw Brzezniak, Ben Goldys, Szymon Peszat, Francesco Russo. Second Order PDEs with Dirichlet White Noise Boundary Condition. 2013. ⟨hal-00825120⟩
235 Consultations
248 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
