Classical eddy current losses in Soft Magnetic Composites - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Physics Année : 2013
This paper deals with the problem of loss evaluation in Soft Magnetic Composites (SMCs), focusing on the classical loss component. It is known that eddy currents can flow in these granular materials at two different scales, that of the single particle (microscopic eddy currents) and that of the specimen cross-section (macroscopic eddy currents), the latter ensuing from imperfect insulation between particles. It is often argued that this macroscopic loss component can be calculated considering an equivalent homogeneous material of same bulk resistivity. This assumption has not found so far clear and general experimental validation. In this paper, we discuss energy loss experiments in two different SMC materials, obtained using different binder types, and we verify that a classical macroscopic loss component, the sole size-dependent term, can be separately identified. It is also put in evidence that, depending on the material, the measured sample resistivity and the equivalent resistivity entering the calculation of the macroscopic eddy currents may not be the same. A corrective coefficient is, therefore, introduced and experimentally identified. This coefficient appears to depend on the material type only. An efficient way to calculate the macroscopic classical loss in these materials is thus provided.
art_v2.pdf (109.45 Ko) Télécharger le fichier
hal-00825523 , version 1 (23-05-2013)
  • HAL Id : hal-00825523 , version 1
Carlo Appino, Olivier de La Barrière, F . Fiorillo, Martino Lobue, Frédéric Mazaleyrat, et al.. Classical eddy current losses in Soft Magnetic Composites. Journal of Applied Physics, 2013, 113 (17), pp 17A322-1 - 17A322-3. ⟨hal-00825523⟩
227 Consultations
890 Téléchargements
