Conference papers
Pareto-Based Multiobjective AI Planning
Mostepha Redouane Khouadjia 1 Marc Schoenauer 1, 2 Vincent Vidal 3 Johann Dréo 4 Pierre Savéant 4
1 TAO - Machine Learning and Optimisation
LRI - Laboratoire de Recherche en Informatique, UP11 - Université Paris-Sud - Paris 11, Inria Saclay - Ile de France, CNRS - Centre National de la Recherche Scientifique : UMR8623
Abstract : Real-world problems generally involve several antagonistic objectives, like quality and cost for design problems, or makespan and cost for planning problems. The only approaches to multiobjective AI Planning rely on metrics, that can incorporate several objectives in some linear combinations, and metric sensitive planners, that are able to give different plans for different metrics, and hence to eventually approximate the Pareto front of the multiobjective problem, i.e. the set of optimal trade-offs between the antagonistic objectives. Divide-and-Evolve (DaE) is an evolutionary planner that embeds a classical planner and feeds it with a sequence of subproblems of the problem at hand. Like all Evolutionary Algorithms, DaE can be turned into a Pareto-based multiobjective solver, even though using an embedded planner that is not metric sensitive. The Pareto-based multiobjective planner MO-DaE thus avoids the drawbacks of the aggregation method. Furthermore, using YAHSP as the embedded planner, it outperforms in many cases the metric-based approach using LPG metric sensitive planner, as witnessed by experimental results on original multiobjective benchmarks built upon IPC-2011 domains.
Complete list of metadatas
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-00835003
Contributor : Marc Schoenauer <>
Submitted on : Wednesday, June 19, 2013 - 11:13:08 AM
Last modification on : Monday, February 10, 2020 - 5:40:08 PM
Document(s) archivé(s) le : Friday, September 20, 2013 - 4:05:51 AM
File
567final.pdf
Identifiers
  • HAL Id : hal-00835003, version 2
Collections
Citation
Mostepha Redouane Khouadjia, Marc Schoenauer, Vincent Vidal, Johann Dréo, Pierre Savéant. Pareto-Based Multiobjective AI Planning. IJCAI 2013, IJCAI/AAAI, Aug 2013, Beijing, China. pp.2321-2327. ⟨hal-00835003v2⟩
Share
Metrics
Record views
467
Files downloads
685
