Conference papers
Audio Oracle Analysis of Musical Information Rate
Abstract : This paper presents a method for analysis of changes in information contents in music based on an audio representation called Audio Oracle (AO). Using compression properties of AO we estimate the amount of information that passes between the past and the present at every instance in a musical signal. This formulation extends the notion of Information Rate (IR) to individual sequences and allows an optimal estimation of the AO threshold parameter. We show that changes in IR correspond to significant musical structures such as sections in a sonata form. Relation to musical perception and applications for composition and improvisation are discussed in the paper.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-00839065
Contributor : Arshia Cont Connect in order to contact the contributor
Submitted on : Friday, June 28, 2013 - 4:19:37 PM
Last modification on : Tuesday, March 15, 2022 - 3:22:05 AM
Long-term archiving on: : Sunday, September 29, 2013 - 4:35:44 AM
File
Dubnov2011a.pdf
Identifiers
  • HAL Id : hal-00839065, version 1
Citation
Shlomo Dubnov, Gérard Assayag, Arshia Cont. Audio Oracle Analysis of Musical Information Rate. Proceedings of IEEE Semantic Computing Conference (ICSC2011), 2011, Unknown, United States. pp.567--571. ⟨hal-00839065⟩
Share
Metrics
Record views
236
Files downloads
614
