Audio Oracle Analysis of Musical Information Rate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a method for analysis of changes in information contents in music based on an audio representation called Audio Oracle (AO). Using compression properties of AO we estimate the amount of information that passes between the past and the present at every instance in a musical signal. This formulation extends the notion of Information Rate (IR) to individual sequences and allows an optimal estimation of the AO threshold parameter. We show that changes in IR correspond to significant musical structures such as sections in a sonata form. Relation to musical perception and applications for composition and improvisation are discussed in the paper.
Dubnov2011a.pdf (437.42 Ko) Télécharger le fichier
hal-00839065 , version 1 (28-06-2013)
  • HAL Id : hal-00839065 , version 1
Shlomo Dubnov, Gérard Assayag, Arshia Cont. Audio Oracle Analysis of Musical Information Rate. Proceedings of IEEE Semantic Computing Conference (ICSC2011), 2011, Unknown, United States. pp.567--571. ⟨hal-00839065⟩
239 Consultations
678 Téléchargements
