Weak rate of convergence of the Euler-Maruyama scheme for stochastic differential equations with non-regular drift
Abstract : We consider an Euler-Maruyama type approximation method for a stochastic differential equation (SDE) with a non-regular drift and regular diffusion coefficient. The method regu-larizes the drift coefficient within a certain class of functions and then the Euler-Maruyama scheme for the regularized scheme is used as an approximation. This methodology gives two errors. The first one is the error of regularization of the drift coefficient within a given class of parametrized functions. The second one is the error of the regularized Euler-Maruyama scheme. After an optimization procedure with respect to the parameters we obtain various rates, which improve other known results.
Document type :
Journal articles
Complete list of metadatas
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-00840211
Contributor : Antoine Lejay <>
Submitted on : Thursday, July 6, 2017 - 8:55:17 PM
Last modification on : Monday, October 8, 2018 - 9:28:06 PM
Long-term archiving on: Wednesday, January 24, 2018 - 7:24:26 AM
File
kohatsu-lejay-yasuda_Finale.pd...
Identifiers
Citation
Arturo Kohatsu-Higa, Antoine Lejay, Kazuhiro Yasuda. Weak rate of convergence of the Euler-Maruyama scheme for stochastic differential equations with non-regular drift. Journal of Computational and Applied Mathematics, Elsevier, 2017, 326C, pp.138-158. ⟨10.1016/j.cam.2017.05.015⟩. ⟨hal-00840211v5⟩
Share
Metrics
Record views
286
Files downloads
478
