B-tests: Low Variance Kernel Two-Sample Tests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A family of maximum mean discrepancy (MMD) kernel two-sample tests is introduced. Members of the test family are called Block-tests or B-tests, since the test statistic is an average over MMDs computed on subsets of the samples. The choice of block size allows control over the tradeoff between test power and computation time. In this respect, the $B$-test family combines favorable properties of previously proposed MMD two-sample tests: B-tests are more powerful than a linear time test where blocks are just pairs of samples, yet they are more computationally efficient than a quadratic time test where a single large block incorporating all the samples is used to compute a U-statistic. A further important advantage of the B-tests is their asymptotically Normal null distribution: this is by contrast with the U-statistic, which is degenerate under the null hypothesis, and for which estimates of the null distribution are computationally demanding. Recent results on kernel selection for hypothesis testing transfer seamlessly to the B-tests, yielding a means to optimize test power via kernel choice.
nips2013.pdf (2.27 Mo) Télécharger le fichier
hal-00842098 , version 1 (07-07-2013)
hal-00842098 , version 2 (21-11-2013)
hal-00842098 , version 3 (10-02-2014)
Wojciech Zaremba, Arthur Gretton, Matthew Blaschko. B-tests: Low Variance Kernel Two-Sample Tests. Neural Information Processing Systems, Dec 2013, Lake Tahoe, United States. ⟨hal-00842098v2⟩
326 Consultations
916 Téléchargements
