Reconstruction of solutions to the Helmholtz equation from punctual measurements
We analyze the sampling of solutions to the Helmholtz equation (e.g. sound fields in the harmonic regime) using a least-squares method based on approximations of the solutions by sums of Fourier-Bessel functions or plane waves. This method compares favorably to others such as Orthogonal Matching Pursuit with a Fourier dictionary. We show that using a significant proportion of samples on the border of the domain of interest improves the stability of the reconstruction, and that using cross-validation to estimate the model order yields good reconstruction results.
