Optimal life-history strategies in seasonal consumer-resource dynamics. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Evolution - International Journal of Organic Evolution Année : 2011
The interplay between individual adaptive life histories and populations dynamics is an important issue in ecology. In this context, we considered a seasonal consumer-resource model with nonoverlapping generations. We focused on the consumers decision-making process through which they maximize their reproductive output via a differential investment into foraging for resources or reproducing. Our model takes a semi-discrete form, and is composed of a continuous time within-season part, similar to a dynamic model of energy allocation, and of a discrete time part, depicting the between seasons reproduction and mortality processes. We showed that the optimal foraging-reproduction strategies of the consumers may be "determinate" or "indeterminate" depending on the season length. More surprisingly, it depended on the consumers population density as well, with large densities promoting indeterminacy. A bifurcation analysis showed that the long-term dynamics produced by this model were quite rich, ranging from both populations' extinction, coexistence at some season-to-season equilibrium or on (quasi)-periodic motions, to initial condition-dependent dynamics. Interestingly, we observed that any long-term sustainable situation corresponds to indeterminate consumers' strategies. Finally, a comparison with a model involving typical nonoptimal consumers highlighted the stabilizing effects of the optimal life histories of the consumers.
akhmetzhanov_etal_revised.pdf (505 Ko) Télécharger le fichier
hal-00848376 , version 1 (26-07-2013)
Andrei R. Akhmetzhanov, Frédéric Grognard, Ludovic Mailleret. Optimal life-history strategies in seasonal consumer-resource dynamics.. Evolution - International Journal of Organic Evolution, 2011, 65 (11), pp.3113--3125. ⟨10.1111/j.1558-5646.2011.01381.x⟩. ⟨hal-00848376⟩
301 Consultations
163 Téléchargements
