A Dynamic Model for Anaerobic Digestion of Microalgae - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The coupling between a microalgal pond and an anaerobic digester is a promising alternative for sustainable energy production by transforming carbon dioxide into methane (which is a biofuel). In this paper, a dynamic model for anaerobic digestion of microalgae is developed with the objective of helping in the coupled process management. This model includes the dynamics of ammonium and volatile fatty acids since both can lead to inhibition and process unstability. Three reactions are considered: two hydrolysis-acetogenesis steps in parallel for the sugars-lipids and for the proteins, and a methanogenesis step. Simulation results were compared with experimental data for Chlorella vulgaris digestion. The model fits the data of the considered 140 day experiment.
hal-00848431 , version 1 (26-07-2013)
Francis Mairet, Olivier Bernard, Monique Ras, Laurent Lardon, Jean-Philippe Steyer. A Dynamic Model for Anaerobic Digestion of Microalgae. IFAC World Congress, 2011, Milano, Italy. ⟨10.3182/20110828-6-IT-1002.02636⟩. ⟨hal-00848431⟩
248 Consultations
0 Téléchargements
