Higher-Order Tensors in Diffusion Imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
Diffusion imaging is a noninvasive tool for probing the microstructure of fibrous nerve and muscle tissue. Higher-order tensors provide a powerful mathematical language to model and analyze the large and complex data that is generated by its modern variants such as High Angular Resolution Diffusion Imaging (HARDI) or Diffusional Kurtosis Imaging. This survey gives a careful introduction to the foundations of higher-order tensor algebra, and explains how some concepts from linear algebra generalize to the higher-order case. From the application side, it reviews a variety of distinct higher-order tensor models that arise in the context of diffusion imaging, such as higher-order diffusion tensors, q-ball or fiber Orientation Distribution Functions (ODFs), and fourth-order covariance and kurtosis tensors. By bridging the gap between mathematical foundations and application, it provides an introduction that is suitable for practitioners and applied mathematicians alike, and propels the field by stimulating further exchange between the two.
tensors-in-dwi-FINAL-Schultz.pdf (216.11 Ko) Télécharger le fichier
hal-00848526 , version 1 (26-07-2013)
  • HAL Id : hal-00848526 , version 1
Thomas Schultz, Andrea Fuster, Aurobrata Ghosh, Rachid Deriche, Luc Florack, et al.. Higher-Order Tensors in Diffusion Imaging. Burgeth, B. and Vilanova, A. and Westin, C. F. Visualization and Processing of Tensors and Higher Order Descriptors for Multi-Valued Data. Dagstuhl Seminar 2011, Springer, 2013. ⟨hal-00848526⟩
310 Consultations
738 Téléchargements
