Solving highly-oscillatory NLS with SAM: numerical efficiency and geometric properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series S Année : 2016
In this paper, we present the Stroboscopic Averaging Method (SAM), recently introduced in [7,8,10,12], which aims at numerically solving highly-oscillatory differential equations. More specifically, we first apply SAM to the Schrödinger equation on the 1-dimensional torus and on the real line with harmonic potential, with the aim of assessing its efficiency: as compared to the well-established standard splitting schemes, the stiffer the problem is, the larger the speed-up grows (up to a factor 100 in our tests). The geometric properties of SAM are also explored: on very long time intervals, symmetric implementations of the method show a very good preservation of the mass invariant and of the energy. In a second series of experiments on 2-dimensional equations, we demonstrate the ability of SAM to capture qualitatively the long-time evolution of the solution (without spurring high oscillations).
hal-00850513 , version 1 (07-08-2013)
Philippe Chartier, Norbert J. Mauser, Florian Méhats, Yong Zhang. Solving highly-oscillatory NLS with SAM: numerical efficiency and geometric properties. Discrete and Continuous Dynamical Systems - Series S, 2016, 9 (5), pp.1327-1349. ⟨10.3934/dcdss.2016053⟩. ⟨hal-00850513⟩
296 Consultations
0 Téléchargements
