Comparison of Hardware and Software Based Encryption for Secure Communication in Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the energy efficient issue of cryptographic mechanisms used for secure communication between devices in wireless sensor networks. Since these devices are mainly targeted for low power consumption appliances, there is an effort for optimization of any aspects needed for regular sensor operation. On a basis of utilization of hardware cryptographic accelerators integrated in microcontrollers, this article provides the comparison between software and hardware solutions. Proposed work examines the problems and solutions for implementation of security algorithms for WSN devices. Because the speed of hardware accelerator should be much higher than the software implementation, there are examination tests of energy consumption and validation of performance of this feature. Main contribution of the article is real testbed evaluation of the time latency and energy requirements needed for securing the communication. In addition, global evaluation for all important network communication parameters like throughput, delay and delivery ratio are also provided.
PID2759333.pdf (2.08 Mo) Télécharger le fichier
hal-00850899 , version 1 (09-08-2013)
  • HAL Id : hal-00850899 , version 1
Miroslav Botta, Milan Simek, Nathalie Mitton. Comparison of Hardware and Software Based Encryption for Secure Communication in Wireless Sensor Networks. 36th International Conference on Telecommunications and Signal Processing (TSP), Jul 2013, Rome, Italy. ⟨hal-00850899⟩
Collections
INRIA INRIA2
146 Consultations
1731 Téléchargements
