Private announcement and belief expansion: an internal perspective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Logic and Computation Année : 2012
Guillaume Aucher
AGM belief revision theory and the BMS framework of dynamic epistemic logic both deal with the formalization of belief change, the former in a single agent setting and the latter in a multiagent setting. In this paper we study the relation between these two formalisms. To be fair, we restrict our attention to the AGM operation of expansion since the original BMS framework does not allow for belief revision. Likewise, because AGM theory follows the internal approach, instead of the original BMS framework we define and deal with its internal version. This allows us to show that the AGM operation of expansion can naturally be viewed in the multi-agent setting of the BMS framework as the operation of private announcement, which goes against the claims of [16]. In parallel, we also provide conditions under which seriality of accessibility relations is preserved during an update, in the BMS framework as well as its internal version: it is a preliminary step towards the introduction of revision mechanisms into these frameworks.
Journal_of_Logic_and_Computation.PDF (354.76 Ko) Télécharger le fichier
hal-00856474 , version 1 (01-09-2013)
  • HAL Id : hal-00856474 , version 1
Guillaume Aucher. Private announcement and belief expansion: an internal perspective. Journal of Logic and Computation, 2012. ⟨hal-00856474⟩
Collections
IRISA-D4
186 Consultations
205 Téléchargements
