Learning-induced modulation of scale-free properties of brain activity measured with MEG - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Previous studies have suggested that infraslow brain activity could play an important role in cognition. Its scale-free properties (coarsely described by its 1/f power spectrum) are indeed modulated between contrasted conscious states (sleep vs. awake). However, finer modulations remain to be investigated. Here, we make use of a robust multifractal analysis to investigate the group-level impact of perceptual learning (visual (V), or audiovisual (AV), N=12 subjects in each group) on the source reconstructed scale-free activity recorded with magnetoencephalography (MEG) during rest and task. We first observed a significant decrease of self-similarity in evoked activity during the task after both trainings. More interestingly, only the most efficient training (AV) induced a decrease of self-similarity in spontaneous activity at rest whereas only V training induced an increase of multifractality in evoked activity.
isbi13_zilber.pdf (556.77 Ko) Télécharger le fichier
hal-00859389 , version 1 (07-09-2013)
Nicolas Zilber, Philippe Ciuciu, Patrice Abry, Virginie van Wassenhove. Learning-induced modulation of scale-free properties of brain activity measured with MEG. 10th IEEE International Symposium on Biomedical Imaging, IEEE, Apr 2013, San Francisco, United States. pp.998-1001, ⟨10.1109/ISBI.2013.6556645⟩. ⟨hal-00859389⟩
569 Consultations
441 Téléchargements
