Design of a Cascade Observer for a Model of Bacterial Batch Culture with Nutrient Recycling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A mathematical model of microbial growth on a single limited substrate in batch culture is proposed as an extension of the Monod's one. This model takes into account cell mortality, non-viable cell accumulation and cell recycling. We consider that only substrate concentration and total biomass are measured on-line. The parameters of the model are not identifiable at steady state, but we propose a design of an observer that reconstructs both parameters and state variable with a practical convergence, from any initial condition away from the equilibrium. The observer is build as a coupling of two non-linear observers in cascade with different time scales.
hal-00859562 , version 1 (09-09-2013)
Alain Rapaport, Miled El Hajji. Design of a Cascade Observer for a Model of Bacterial Batch Culture with Nutrient Recycling. 11th International Symposium on Computer Applications in Biotechnology (CAB 2010), Jul 2010, Leuven, Belgium. pp.203-208, ⟨10.3182/20100707-3-BE-2012.0038⟩. ⟨hal-00859562⟩
143 Consultations
0 Téléchargements
