When are increment-stationary random point sets stationary? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Communications in Probability Année : 2014
In a recent work, Blanc, Le Bris, and Lions defined a notion of increment-stationarity for random point sets, which allowed them to prove the existence of a thermodynamic limit for two-body potential energies on such point sets (under the additional assumption of ergodicity), and to introduce a variant of stochastic homogenization for increment-stationary coefficients. Whereas stationary random point sets are increment-stationary, it is not clear a priori under which conditions increment-stationary random point sets are stationary. In the present contribution, we give a characterization of the equivalence of both notions of stationarity based on elementary PDE theory in the probability space. This allows us to give conditions on the decay of a covariance function associated with the random point set, which ensure that increment-stationary random point sets are stationary random point sets up to a random translation with bounded second moment in dimensions $d>2$. In dimensions $d=1$ and $d=2$, we show that such sufficient conditions cannot exist.
StationaryRPS2.pdf (298.36 Ko) Télécharger le fichier
hal-00863414 , version 1 (18-09-2013)
hal-00863414 , version 2 (25-02-2014)
hal-00863414 , version 3 (03-09-2014)
Antoine Gloria. When are increment-stationary random point sets stationary?. Electronic Communications in Probability, 2014, 19 (30), pp.1-14. ⟨10.1214/ECP.v19-3288⟩. ⟨hal-00863414v2⟩
260 Consultations
196 Téléchargements
