A systemic and cognitive approach for IoT security - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Internet of Things (IoT) will enable objects to become active participants of everyday activities. Introducing objects into the control processes of complex systems makes IoT security very difficult to address. Indeed, the Internet of Things is a complex paradigm in which people interact with the technological ecosystem based on smart objects through complex processes. The interactions of these four IoT components, person, intelligent object, technological ecosystem, and process, highlight a systemic and cognitive dimension within security of the IoT. The interaction of people with the technological ecosystem requires the protection of their privacy. Similarly, their interaction with control processes requires the guarantee of their safety. Processes must ensure their reliability and realize the objectives for which they are designed. We believe that the move towards a greater autonomy for objects will bring the security of technologies and processes and the privacy of individuals into sharper focus. Furthermore, in parallel with the increasing autonomy of objects to perceive and act on the environment, IoT security should move towards a greater autonomy in perceiving threats and reacting to attacks, based on a cognitive and systemic approach. In this work, we will analyze the role of each of the mentioned actors in IoT security and their relationships, in order to highlight the research challenges and present our approach to these issues based on a holistic vision of IoT security.
1569824959-EDAS.pdf (601.57 Ko) Télécharger le fichier
hal-00863955 , version 1 (10-02-2014)
  • HAL Id : hal-00863955 , version 1
Arbia Riahi, Enrico Natalizio, Yacine Challal, Nathalie Mitton, Antonio Iera. A systemic and cognitive approach for IoT security. International Conference on Computing, Networking and Communications (ICNC), Feb 2014, Honolulu, United States. ⟨hal-00863955⟩
466 Consultations
2213 Téléchargements
