Solving BDD by Enumeration: An Update - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bounded Distance Decoding (BDD) is a basic lattice problem used in cryptanalysis: the security of most lattice-based encryption schemes relies on the hardness of some BDD, such as LWE. We study how to solve BDD using a classical method for finding shortest vectors in lattices: enumeration with pruning speedup, such as Gama-Nguyen-Regev extreme pruning from EUROCRYPT '10. We obtain significant improvements upon Lindner-Peikert's Search-LWE algorithm (from CT-RSA '11), and update experimental cryptanalytic results, such as attacks on DSA with partially known nonces and GGH encryption challenges. Our work shows that any security estimate of BDD-based cryptosystems must take into account enumeration attacks, and that BDD enumeration can be practical even in high dimension like 350.
Mots clés
LiuNguyen.pdf (228.89 Ko) Télécharger le fichier
hal-00864361 , version 1 (21-09-2013)
Mingjie Liu, Phong Q. Nguyen. Solving BDD by Enumeration: An Update. CT-RSA 2013 - The Cryptographers' Track at the RSA Conference 2013, Feb 2013, San Francisco, United States. pp.293-309, ⟨10.1007/978-3-642-36095-4_19⟩. ⟨hal-00864361⟩
465 Consultations
2586 Téléchargements
