Constituency and Dependency Relationship from a Tree Adjoining Grammar and Abstract Categorial Grammar Perspective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper gives an Abstract Categorial Grammar (ACG) account of (Kallmeyer and Kuhlmann, 2012)'s process of transformation of the derivation trees of Tree Adjoining Grammar (TAG) into dependency trees. We make explicit how the requirement of keeping a direct interpretation of dependency trees into strings results into lexical ambiguity. Since the ACG framework has already been used to provide a logical semantics from TAG derivation trees, we have a unified picture where derivation trees and dependency trees are related but independent equivalent ways to account for the same surface--meaning relation.
tagTOdep.pdf (329.29 Ko) Télécharger le fichier
hal-00868363 , version 1 (01-10-2013)
  • HAL Id : hal-00868363 , version 1
Aleksandre Maskharashvili, Sylvain Pogodalla. Constituency and Dependency Relationship from a Tree Adjoining Grammar and Abstract Categorial Grammar Perspective. Proceedings of the Sixth International Joint Conference on Natural Language Processing (IJCNLP 2013), The Asian Federation of Natural Language Processing, Oct 2013, Nagoya, Japan. pp.1257-1263. ⟨hal-00868363⟩
358 Consultations
236 Téléchargements
