Improved Alternative Route Planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present improved methods for computing a set of alternative source-to-destination routes in road networks in the form of an alternative graph. The resulting alternative graphs are characterized by minimum path overlap, small stretch factor, as well as low size and complexity. Our approach improves upon a previous one by introducing a new pruning stage preceding any other heuristic method and by introducing a new filtering and fine-tuning of two existing methods. Our accompanying experimental study shows that the entire alternative graph can be computed pretty fast even in continental size networks.
10.pdf (2.15 Mo) Télécharger le fichier
hal-00871739 , version 1 (10-10-2013)
Andreas Paraskevopoulos, Christos Zaroliagis. Improved Alternative Route Planning. ATMOS - 13th Workshop on Algorithmic Approaches for Transportation Modelling, Optimization, and Systems - 2013, Sep 2013, Sophia Antipolis, France. pp.108--122, ⟨10.4230/OASIcs.ATMOS.2013.108⟩. ⟨hal-00871739⟩
Collections
ATMOS2013
392 Consultations
1078 Téléchargements
