Column Generation for Bi-Objective Vehicle Routing Problems with a Min-Max Objective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Boadu Mensah Sarpong
  • Fonction : Auteur
  • PersonId : 769534
  • IdRef : 18142150X
Christian Artigues
Nicolas Jozefowiez
  • Fonction : Auteur
  • PersonId : 941244
Column generation has been very useful in solving single objective vehicle routing problems (VRPs). Its role in a branch-and-price algorithm is to compute a lower bound which is then used in a branch-and-bound framework to guide the search for integer solutions. In spite of the success of the method, only a few papers treat its application to multi-objective problems and this paper seeks to contribute in this respect. We study how good lower bounds for bi-objective VRPs in which one objective is a min-max function can be computed by column generation. A way to model these problems as well as a strategy to effectively search for columns are presented. We apply the ideas to two VRPs and our results show that strong lower bounds for this class of problems can be obtained in "reasonable" times if columns are intelligently managed. Moreover, the quality of the bounds obtained from the proposed model are significantly better than those obtained from the corresponding "standard" approach.
12.pdf (463.82 Ko) Télécharger le fichier
hal-00871741 , version 1 (10-10-2013)
Boadu Mensah Sarpong, Christian Artigues, Nicolas Jozefowiez. Column Generation for Bi-Objective Vehicle Routing Problems with a Min-Max Objective. ATMOS - 13th Workshop on Algorithmic Approaches for Transportation Modelling, Optimization, and Systems - 2013, Sep 2013, Sophia Antipolis, France. pp.137--149, ⟨10.4230/OASIcs.ATMOS.2013.137⟩. ⟨hal-00871741⟩
293 Consultations
310 Téléchargements
