Surgical Process Mining with Test and Flip Net Synthesis
Surgical process modeling aims at providing an explicit representation of surgical procedural knowledge. Surgical process models are inferred from a set of surgical procedure recordings, and represent in a concise manner concurrency, causality and conflict relations between actions. The paper presents preliminary results regarding the use of test and flip nets, a mild extension of flip-flop nets, to represent surgical process models. A test and flip net synthesis algorithm, based on linear algebraic methods in the Z/2Z ring is detailed. Experimental results regarding the use of this synthesis algorithm to automate the construction of simple surgical process models are also presented.
Autre [cs.OH]
