Mathematical modeling of electromagnetic wave propagation in heterogeneous lossy coaxial cables with variable cross section - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Numerical Mathematics Année : 2013
In this work, we focus on the time-domain simulation of the propagation of electromagnetic waves in non-homogeneous lossy coaxial cables. The full 3D Maxwell equations, that described the propagation of current and elec- tric potential in such cables, are classically not tackled directly, but instead a 1D scalar model known as the telegraphist's model is used. We aim at justifying, by means of asymptotic analysis, a time-domain "homogenized" telegraphist's model. This model, which includes a non-local in time op- erator, is obtained via asymptotic analysis, for a lossy coaxial cable whose cross-section is not homogeneous.
coax_elsevier2.pdf (1.27 Mo) Télécharger le fichier
hal-00875811 , version 1 (22-10-2013)
Sébastien Imperiale, Patrick Joly. Mathematical modeling of electromagnetic wave propagation in heterogeneous lossy coaxial cables with variable cross section. Applied Numerical Mathematics, 2013, ⟨10.1016/j.apnum.2013.03.011⟩. ⟨hal-00875811⟩
533 Consultations
940 Téléchargements
