Generalized Robin-Neumann explicit coupling schemes for incompressible fluid-structure interaction: stability analysis and numerics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Engineering Année : 2015
We introduce a new class of explicit coupling schemes for the numerical solution of fluid-structure interaction problems involving a viscous incompressible fluid and an elastic structure. These methods generalize the arguments reported in [13, 10] to the case of the coupling with thick-walled structures. The basic idea lies in the derivation of an intrinsic interface Robin consistency at the space semi-discrete level, using a lumped-mass approximation in the structure. The fluid-solid splitting is then performed through appropriate extrapolations of the solid velocity and stress on the interface. Based on these methods, a new, parameter-free, Robin-Neumann iterative procedure is also proposed for the partitioned solution of implicit coupling. A priori energy estimates, guaranteeing the (added-mass free) stability of the schemes and the convergence of the iterative procedure, are established. The accuracy and robustness of the methods are illustrated in several numerical examples.
RR-8384.pdf (2.63 Mo) Télécharger le fichier
hal-00875819 , version 1 (24-10-2013)
Miguel Angel Fernández, Jimmy Mullaert, Marina Vidrascu. Generalized Robin-Neumann explicit coupling schemes for incompressible fluid-structure interaction: stability analysis and numerics. International Journal for Numerical Methods in Engineering, 2015, 101 (3), pp.199-229. ⟨10.1002/nme.4785⟩. ⟨hal-00875819⟩
839 Consultations
560 Téléchargements
