3D view synthesis with inter-view consistency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a new pipeline to synthesize virtual views by extrapolation. It allows us to generate virtual views far away from each other, each presenting the exact same level of quality. This inter-view consistency is key to seamlessly navigate between viewpoints. Its computational cost is also lower than that of existing approaches. We compare the proposed approach with state-of-the-art methods and show the effectiveness of this new view synthesis pipeline.
Wolinsky_acm2013.pdf (11.44 Mo) Télécharger le fichier
poster.pdf (1 Mo) Télécharger le fichier
Format : Autre
hal-00876171 , version 1 (23-10-2013)
  • HAL Id : hal-00876171 , version 1
David Wolinski, Olivier Le Meur, Josselin Gautier. 3D view synthesis with inter-view consistency. ACM Multimedia, Oct 2013, Barcelone, Spain. ⟨hal-00876171⟩
238 Consultations
207 Téléchargements
