The singularity expansion method applied to the transient motions of a floating elastic plate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2007
In this paper we propose an original approach for the simulation of the time-dependent response of a floating elastic plate using the so-called Singularity Expansion Method. This method consists in computing an asymptotic behaviour for large time obtained by means of the Laplace transform by using the analytic continuation of the resolvent of the problem. This leads to represent the solution as the sum of a discrete superposition of exponentially damped oscillating motions associated to the poles of the analytic continuation called resonances of the system, and a low frequency component associated to a branch point at frequency zero. We present the mathematical analysis of this method for the two-dimensional sea-keeping problem of a thin elastic plate (ice floe, floating runway, ...) and provide some numerical results to illustrate and discuss its efficiency. © EDP Sciences, SMAI 2007.
hal-00876228 , version 1 (25-10-2013)
Christophe Hazard, François Loret. The singularity expansion method applied to the transient motions of a floating elastic plate. ESAIM: Mathematical Modelling and Numerical Analysis, 2007, 41 (5), pp.925-943. ⟨10.1051/m2an:2007040⟩. ⟨hal-00876228⟩
125 Consultations
0 Téléchargements
