Estimation for Stochastic Damping Hamiltonian Systems under Partial Observation. II Drift term - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
This paper is the second part of our study started with \citet*{CLP}. For some ergodic hamiltonian systems we obtained a central limit theorem for a non-parametric estimator of the invariant density, under partial observation (only the positions are observed). Here we obtain similarly a central limit theorem for a non-parametric estimator of the drift term. This theorem lies on the previous result for the invariant density.
CattiauxLeonPrieur.pdf (725.71 Ko) Télécharger le fichier
hal-00877054 , version 1 (25-10-2013)
hal-00877054 , version 2 (29-06-2014)
  • HAL Id : hal-00877054 , version 1
Patrick Cattiaux, José R. León, Clémentine Prieur. Estimation for Stochastic Damping Hamiltonian Systems under Partial Observation. II Drift term. 2013. ⟨hal-00877054v1⟩
445 Consultations
223 Téléchargements
