Linear Convergence of Comparison-based Step-size Adaptive Randomized Search via Stability of Markov Chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
Nikolaus Hansen
In this paper, we consider \emph{comparison-based} adaptive stochastic algorithms for solving numerical optimisation problems. We consider a specific subclass of algorithms called comparison-based step-size adaptive randomized search (CB-SARS), where the state variables at a given iteration are a vector of the search space and a positive parameter, the step-size, typically controlling the overall standard deviation of the underlying search distribution. We investigate the linear convergence of CB-SARS on \emph{scaling-invariant} objective functions. Scaling-invariant functions preserve the ordering of points with respect to their function value when the points are scaled with the same positive parameter (the scaling is done w.r.t. a fixed reference point). This class of functions includes norms composed with strictly increasing functions as well as \emph{non quasi-convex} and \emph{non-continuous} functions. On scaling-invariant functions, we show the existence of a homogeneous Markov chain, as a consequence of natural invariance properties of CB-SARS (essentially scale-invariance and invariance to strictly increasing transformation of the objective function). We then derive sufficient conditions for asymptotic \emph{global linear convergence} of CB-SARS, expressed in terms of different stability conditions of the normalised homogeneous Markov chain (irreducibility, positivity, Harris recurrence, geometric ergodicity) and thus define a general methodology for proving global linear convergence of CB-SARS algorithms on scaling-invariant functions.
LinearCVASARS-AugerHansen.pdf (582.29 Ko) Télécharger le fichier
hal-00877160 , version 1 (27-10-2013)
hal-00877160 , version 2 (29-10-2013)
hal-00877160 , version 3 (01-11-2013)
hal-00877160 , version 4 (25-04-2014)
hal-00877160 , version 5 (12-05-2014)
hal-00877160 , version 6 (24-12-2015)
hal-00877160 , version 7 (02-06-2016)
Anne Auger, Nikolaus Hansen. Linear Convergence of Comparison-based Step-size Adaptive Randomized Search via Stability of Markov Chains. 2014. ⟨hal-00877160v5⟩
581 Consultations
377 Téléchargements
