Programming with permissions in Mezzo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present Mezzo, a typed programming language of ML lineage. Mezzo is equipped with a novel static discipline of duplicable and affine permissions, which controls aliasing and ownership. This rules out certain mistakes, including representation exposure and data races, and enables new idioms, such as gradual initialization, memory re-use, and (type)state changes. Although the core static discipline disallows sharing a mutable data structure, Mezzo offers several ways of working around this restriction, including a novel dynamic ownership control mechanism which we dub "adoption and abandon".
pottier-protzenko-mezzo.pdf (257.81 Ko) Télécharger le fichier
hal-00877590 , version 1 (28-10-2013)
François Pottier, Jonathan Protzenko. Programming with permissions in Mezzo. ICFP - The 18th ACM SIGPLAN International Conference on Functional Programming - 2013, Sep 2013, Boston, United States. pp.173-184, ⟨10.1145/2500365.2500598⟩. ⟨hal-00877590⟩
Collections
INRIA INRIA2
154 Consultations
233 Téléchargements
