Surface Circulation from Satellite Images: Reduced Model of the Black Sea - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Estimating surface circulation from satellite images is a hot subject for a large range of applications. Motion estimation from image data has been studied for long in the literature of Image Processing, and more recently in that of Data Assimilation (DA). This paper describes how the construction of dedicated spaces for projecting motion and image fields allows applying DA methods with a reduced model and eases the estimation of surface circulation on the whole Black Sea basin.
sebastopol2013-v2.pdf (4.17 Mo) Télécharger le fichier
hal-00878071 , version 1 (29-10-2013)
  • HAL Id : hal-00878071 , version 1
Etienne Huot, Isabelle Herlin, Giuseppe Papari, Karim Drifi. Surface Circulation from Satellite Images: Reduced Model of the Black Sea. Integrated system of the Black and Azov seas' monitoring international conference, Marine Hydrophysical Institute, Sep 2013, Kiev, Ukraine. ⟨hal-00878071⟩
219 Consultations
65 Téléchargements
