Universally Composable Key-Management
We present the first universally composable key-management functionality, formalized in the GNUC framework by Hofheinz and Shoup. It allows the enforcement of a wide range of security policies and can be extended by diverse key usage operations with no need to repeat the security proof.We illustrate its use by proving an implementation of a security token secure with respect to arbitrary key-usage operations and explore a proof technique that allows the storage of cryptographic keys externally, a novel development in simulation-based security frameworks.
