Optimal trajectory planning of a 5-axis machine tool based on a 6-axis parallel manipulator. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2000
Many new machine-tool are based on a hexapod structure, a parallel robot with 6 DOF, While only 5 of them are needed for the machining operations as the rotation of the end-effector around its normal is not used. We have therefore an extra DoF: we propose an algorithm which is able to determine for almost any trajectory of the machine the values of the extra DoF to ensure that the trajectory lie within the workspace of the robot is singularity -free and furthermore optimize an arbitrary criterion
ark2000.pdf (423.47 Ko) Télécharger le fichier
hal-00906477 , version 1 (19-11-2013)
Jean-Pierre Merlet, M.-W. Perng, David Daney. Optimal trajectory planning of a 5-axis machine tool based on a 6-axis parallel manipulator.. Lenarčič, J. and Stanišić, M.M. Advances in Robot Kinematics, Springer, pp.315-322, 2000, 978-94-010-5803-2. ⟨10.1007/978-94-011-4120-8_33⟩. ⟨hal-00906477⟩
185 Consultations
210 Téléchargements
