Appropriate Design of Parallel Manipulators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2008
Although parallel structures have found a niche market in many applications such as machine tools, telescope positioning or food packaging, they are not as successful as expected. The main reason of this relative lack of success is that the study and hardware of parallel structures have clearly not reached the same level of completeness than the one of serial structures. Among the main issues that have to be addressed, the design problem is crucial. Indeed, the performances that can be expected from a parallel robot are heavily dependent upon the choice of the mechanical structure and even more from its dimensioning. In this chapter, we show that classical design methodologies are not appropriate for such closed-loop mechanism and examine what alternatives are possible.
appropriatedesign2008.pdf (539.49 Ko) Télécharger le fichier
hal-00907514 , version 1 (21-11-2013)
Jean-Pierre Merlet, D. Daney. Appropriate Design of Parallel Manipulators. Wang, Lihui and Xi, Jeff. Smart Devices and Machines for Advanced Manufacturing, Springer London, pp.1-25, 2008, 978-1-84800-146-6. ⟨10.1007/978-1-84800-147-3_1⟩. ⟨hal-00907514⟩
128 Consultations
275 Téléchargements
