Runtime Enforcement of Regular Timed Properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Runtime enforcement is a verification/validation technique aiming at correcting (possibly incorrect) executions of a system of interest. In this paper, we consider enforcement monitoring for systems with timing specifications (modeled as timed automata). We consider runtime enforcement of any regular timed property specified by a timed automaton. To ease their design and their correctness-proof, enforcement mechanisms are described at several levels: enforcement functions that specify the input-output behavior, constraints that should be satisfied by such functions, enforcement monitors that implement an enforcement function as a transition system, and enforcement algorithms that describe the implementation of enforcement monitors. The feasibility of enforcement monitoring for timed properties is validated by prototyping the synthesis of enforcement monitors.
sac-svt.pdf (828.46 Ko) Télécharger le fichier
hal-00907571 , version 1 (03-04-2014)
  • HAL Id : hal-00907571 , version 1
Srinivas Pinisetty, Yliès Falcone, Thierry Jéron, Hervé Marchand. Runtime Enforcement of Regular Timed Properties. Software Verification and Testing, track of the Symposium on Applied Computing ACM-SAC 2014, Mar 2014, Gyeongju, South Korea. pp.1279-1286. ⟨hal-00907571⟩
497 Consultations
259 Téléchargements
