Subspace-Based Damage Detection under Changes in the Ambient Excitation Statistics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mechanical Systems and Signal Processing Année : 2014
In the last ten years, monitoring the integrity of the civil infrastructure has been an active research topic, including in connected areas as automatic control. It is common practice to perform damage detection by detecting changes in the modal parameters between a reference state and the current (possibly damaged) state from measured vibration data. Subspace methods enjoy some popularity in structural engineering, where large model orders have to be considered. In the context of detecting changes in the structural properties and the modal parameters linked to them, a subspace-based fault detection residual has been recently proposed and applied successfully, where the estimation of the modal parameters in the possibly damaged state is avoided. However, most works assume that the unmeasured ambient excitation properties during measurements of the structure in the reference and possibly damaged condition stay constant, which is hardly satisfied by any application. This paper addresses the problem of robustness of such fault detection methods. It is explained why current algorithms from literature fail when the excitation covariance changes and how they can be modified. Then, an efficient and fast subspace-based damage detection test is derived that is robust to changes in the excitation covariance but also to numerical instabilities that can arise easily in the computations. Three numerical applications show the efficiency of the new approach to better detect and separate different levels of damage even using a relatively low sample length.
detection.pdf (522.82 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00907656 , version 1 (20-04-2020)
Michael Döhler, Laurent Mevel, Falk Hille. Subspace-Based Damage Detection under Changes in the Ambient Excitation Statistics. Mechanical Systems and Signal Processing, 2014, 45, 1, pp.207-224. ⟨10.1016/j.ymssp.2013.10.023⟩. ⟨hal-00907656⟩
293 Consultations
177 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
