Rapport final d'execution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2013
Rapporto finale di esecuzione
myMed is an open source project, which facilitates and accelerates your development of mobile applications and social networks running over a heterogeneous list of platforms, such as Smartphones and Tablets running iOS and Android. myMed provides a rich framework for publishing, searching and subscribing to content: the engine is built on top of a distributed database based on the Cassandra nosql database. In its current version, it provides high scalability and fault tolerance. The myMed framework lets you easily build social web applications: it features geolocalization, points of interest, profile management, and content/user reputation.
2013-rapport-finale-dexecution-rapporto-finale-di-esecuzione-myMed-complet.pdf (4.13 Mo) Télécharger le fichier
hal-00909658 , version 1 (18-05-2015)
  • HAL Id : hal-00909658 , version 1
Luigi Liquori, Claudio Casetti, Mariangiola Dezani-Ciancaglini, Cosimo Anglano. Rapport final d'execution : Contrat myMed - Appel UE Interreg Alcotra. 2013, pp.60. ⟨hal-00909658⟩
125 Consultations
95 Téléchargements
