A particle filter for target arrival detection and tracking in track-before-detect - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we address the problem of detecting the appearance time of a target and tracking its state with a particle filter in the Track-Before-Detect context. We show that it is possible to model the problem as a quickest detection change problem in a Bayesian framework. In this case, the posterior density of the target time appearance is a mixture where each component represents the hypothesis that the target arrived at a given time. As the posterior density is intractable in practice, we propose to approximate each component of the mixture by a particle filter, and we show that the weights of the mixture can be computed recursively thanks to quantities provided by the different particle filters. The overall filter yields good performance.
Fichier non déposé
hal-00911789 , version 1 (29-11-2013)
Alexandre Lepoutre, Olivier Rabaste, François Le Gland. A particle filter for target arrival detection and tracking in track-before-detect. Proceedings of the 2012 Workshop on Sensor Data Fusion: Trends, Solutions, Applications, Bonn 2012, Sep 2012, Bonn, Germany. pp.13-18, ⟨10.1109/SDF.2012.6327901⟩. ⟨hal-00911789⟩
341 Consultations
0 Téléchargements
