The exponential projection filter and the selection of the exponential family
We present the projection filter, an approximate finite-dimensional filter based on the differential geometric approach to statistics. We recall the definition of the projection filter in the case of exponential families, and we give some hints about the selection of the coefficients in the exponential family.
