Time discretization of the Zakai equation for diffusion processes observed in correlated noise
A time discretization scheme is provided for the Zakai equation, a stochastic PDE which gives the conditional law of a diffusion process observed in white-noise. The case where the observation noise and the state noise are correlated, is considered. The numerical scheme is based on a Trotter-like product formula, which exhibits prediction and correction steps, and for which an error estimate of order δ is proved, where δ is the time discretization step. The correction step is associated with a degenerate second-order stochastic PDE, for which a representation result is available in terms of stochastic characteristics. A discretization scheme is then provided to approximate these stochastic characteristics. Under an additional assumption on the correlation coefficient, an error estimate of order √δ is proved for the overall numerical scheme. This has been proved to be the best possible error estimate by Elliott and Glowinski.
