Algebraic Characterization of Observability in Distance-Regular Consensus Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alain Kibangou
In this paper, we study the observability issue in consensus networks modeled with strongly regular graphs or distance regular graphs. We derive a Kalman-like simple algebraic criterion for observability in distance regular graphs. This criterion consists in evaluating the rank of a matrix built with the components of the Bose-Mesner algebra associated with the considered graph. Then, we state a simple necessary condition of observability based on parameters of the graph, namely the diameter, the degree, and the number of vertices of the graph.
observability_SRG_cdc.pdf (167.41 Ko) Télécharger le fichier
hal-00913926 , version 1 (04-12-2013)
  • HAL Id : hal-00913926 , version 1
Alain Kibangou, Christian Commault. Algebraic Characterization of Observability in Distance-Regular Consensus Networks. CDC 2013 - 52nd IEEE Conference on Decision and Control, Dec 2013, Florence, Italy. pp.n/c. ⟨hal-00913926⟩
541 Consultations
234 Téléchargements
