The Goh necessary optimality conditions for the Mayer problem with control constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hélène Frankowska
  • Fonction : Auteur
  • PersonId : 899311
Daniela Tonon
  • Fonction : Auteur
  • PersonId : 949802
The well known Goh second order necessary optimality conditions in optimal control theory concern singular optimal controls taking values in the interior of a set of controls U. In this paper we investigate these conditions for the Mayer problem when U is a convex polytope or a closed subset of class C^2 for an integrable optimal control that may take values in the boundary of U. This is indeed a frequent situation in optimal control and for this reason the understanding of this issue is crucial for the theory of second order optimality conditions. Applying the Goh transformation we derive necessary conditions on tangent subspaces to U. In the presence of an endpoint constraint, if the Mayer problem is calm, then similar second order necessary optimality conditions are satisfied whenever the maximum principle is abnormal. If it is normal, then analogous results hold true on some smaller subspaces.
Fichier non déposé
hal-00917508 , version 1 (11-12-2013)
  • HAL Id : hal-00917508 , version 1
Hélène Frankowska, Daniela Tonon. The Goh necessary optimality conditions for the Mayer problem with control constraints. 52nd IEEE Control and Decision Conference (CDC) (2013), IEEE, Dec 2013, Florence, Italy. pp.538-543. ⟨hal-00917508⟩
176 Consultations
0 Téléchargements
