Case-Based Reasoning on E-Community Knowledge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emmanuelle Gaillard
  • Fonction : Auteur
  • PersonId : 918004
Jean Lieber
Emmanuel Nauer
This paper presents MKM, a meta-knowledge model to manage knowledge reliability, in order to extend a CBR system so that it can reason on partially reliable, non expert, knowledge from the Web. Knowledge reliability is considered from the point of view of the decision maker using the CBR system. It is captured by the MKM model including notions such as belief, trust, reputation and quality, as well as their relationships and rules to evaluate knowledge reliability. We detail both the model and the associated approach to extend CBR. Given a problem to solve for a specific user, reliability estimation is used to filter knowledge with high reliability as well as to rank the results produced by the CBR system, ensuring the quality of results.
Informatique
paper_6.pdf (344.09 Ko) Télécharger le fichier
hal-00918518 , version 1 (13-12-2013)
Emmanuelle Gaillard, Jean Lieber, Yannick Naudet, Emmanuel Nauer. Case-Based Reasoning on E-Community Knowledge. ICCBR 2013 - 21st International Conference on Case-Based Reasoning, Jul 2013, Saratoga Springs, NY, United States. pp.104-118, ⟨10.1007/978-3-642-39056-2_8⟩. ⟨hal-00918518⟩
182 Consultations
326 Téléchargements
