Flauncher and DVMS -- Deploying and Scheduling Thousands of Virtual Machines on Hundreds of Nodes Distributed Geographically
Although live migration of virtual machines has been an active area of research over the past decade, it has been mainly evaluated by means of simulations and small scale deployments. Proving the relevance of live migration at larger scales is a technical challenge that requires to be able to deploy and schedule virtual machines. In the last year, we succeeded to tackle such a challenge by conducting experiments with Flauncher and DVMS, two frameworks that can respectively deploy and schedule thousands of virtual machines over hundreds of nodes distributed geographically across the Grid'5000 testbed.
